LabWindows/CVI
Text editor
HI i was wondering if anybody could assist me, I wanted to know how to add text editor to my gui, meaning if take my cursor and point to a certain spot on my gui
it would display window with info i suggest as a string. etc.................... do anyone know?
(4,151 Views)
nevermind you guys i found it, which is SetCtrlToolTipAttribute,  is there thing else thats new that i can learn to add to my graphical user interface or code period?
anything exciting
(4,150 Views)
hi im getting the error badly pathname form, unable to create executable, how do you fixed this error?
(4,121 Views)
darnell, unfortunately my gazing ball is now under maintenance so I cannot help you on this subject.
Unless you give us some more details about this problem, narrowing it to an understandable situation.
Have you tried searching for this error in the forum? This is the list of related posts: even if no one of them gives a final solution, they give you some hint on how to address this problem.
By the way, this problem is completely unrelated to the previous one: you should have created a new thread for this!
(4,112 Views)
actually i fixed by going to target settings and putting the correct path in for the release mode and debug mode, and it went away. Im getting ready to post another post on typedef struct,
can you assist me?
(4,109 Views)
