uint64_t not recognized statement.
When I declare variable as uint64_t, or unsigned __int64, Labwindows gives me error messages when compile.  It says unrecognized statement.  I included stdint.h and userint.h
What is missing?
Message 1 of 8
(7,410 Views)
Accepted by soljiang
what is missing:
- what version of CVI are you using?
- do you have the Configuration Option 'Buld with C99 extensions' enabled?
- a code sample
For me, using CVI2013SP1, both
uint64_t test;
unsigned __int64 test2;
is working without error...
Message 2 of 8
(7,406 Views)
I didn't turn on Buld with C99 extensions.  Now seems it solved that particular problem.  Thanks!
Message 3 of 8
(7,404 Views)
I wonder, what if I don't have Buld with C99 extensions enabled?  How can I declare a variable to be an unsigned 64 bit integer?  Thanks.
Message 4 of 8
(7,401 Views)
If your question has been answered, please mark the respective post as answer.
For new questions please open a new thread, thanks.
Message 5 of 8
(7,399 Views)
 unsigned __int64 should work without C99 (since CVI 7); C99 extensions are only needed for uint64
Message 6 of 8
(7,389 Views)
Thank you!
Message 7 of 8
(7,384 Views)
you're welcome Smiley Happy
Message 8 of 8
(7,369 Views)
