LabWindows/CVI
uir file
I'm working on an application using CVI 6.0. Temporarily I used CVI 7.0 because I was working on two projects, and now I'm back to 6.0 version.
I have modified a .uir file with 7.0 version, and now I can't open it with 6.0 version. The execution is OK, but I can't modify it.
Have you hot a tool or solution to write a 7.0 uir file to 6.0 format ?
Best regards
(4,059 Views)
Open your UIR in CVI7, select Options >> Save in text format... and load in CVI 6 with the symmetric Load from text format.. option.
(4,056 Views)
I can't find this load option in CVI 6.0. The .tui file opens as a text file, even if I use the open User Interface function.
(4,051 Views)
Open an existing UIR file or create a new one: in the UIR editor window you will find Options >> Load from text format menu item.
(4,049 Views)
OK, done.
Now the problem is "An unspecified error as occurred, probably due to corrupted data at line 1420".
This file opens well in CVI 7.0. May be I should get back an old file in 6.0, and redo the work I've done in 7.0 with 6.0.
(4,047 Views)
@mediane systeme wrote:
OK, done.
You could have used a control or a feature that is specific of CVI 7 and does not exist in 6: by looking at the specified row of the TUI file you could try to understand which is the error. But if the modifications done on the file in version 7 are limited and you have a backup done with version 6, maybe the best is to do it again with the correct IDE.
(4,039 Views)
I think so. I don't understand this line, so I can't "repair" the file.
Many thanks for you great help.
(4,035 Views)
