ungraceful end of editing menu bar
Hello NI,
when preparing a sample project (using CVI2015) I came to editing a menu bar, see screen shot below.
Because I made an error I wanted to delete the entries Menu 2 ... Menu 6.
This - in principle - is possible by either pressing the 'Delete' button or the 'Cut' button several times.
However, if I want to cut the 'Menu 6' entry I get an error 'The index is out of range', the menu editor having crashed, i.e., disappeared without my changes saved.
Using the 'Delete' button works OK, so there is a simple workaround, but still, a crash wasting work is never nice and should be fixed Smiley Wink
Thanks!
(3,858 Views)
Hi Wolfgang,
thank you for reporting this issue.
I reproduced and reported the issue to R&D. The tracking number is 595232.
Melanie
Melanie Eisfeld
Senior Applications Engineer, National Instruments Germany
Certified LabVIEW Developer
Certified TestStand Architect
(3,749 Views)
Thanks!
(3,747 Views)
Accepted by Wolfgang
This bug has been fixed in CVI 2019, thanks Smiley Happy
(2,400 Views)
