LabWindows/CVI
unrecoverable Internal Error at 0023:106FF1EE.LabWindows/CVI will be aborted.
when I debug the code ,wanna open watch windows ,then it show this error,then the application aborted.
(3,574 Views)
Accepted by ellen_du
Try and use ConfigCVILogging.exe, it might give info about what is going on
(3,505 Views)
It is very strange that ,after I run ConfigCVILogging.exe,then debug code,watch window can be opened.yesterday I tried to open it,cvi aborted.
Anyway,the problem is solved.but I couldn't find out the logging file,so don't know the reason.
Ellen
Best Regards
(3,489 Views)
Hi,gdargaud
I set the log file,but couldn't see the file,it is very strange.
and after that time,it is still aborted sometimes.
thanks ,maybe my cvi has problem.
Ellen
BR
(3,449 Views)
