usb activex for cvi 6.0
I am looking for an usb activex for labwindows cvi 6.0 in order to establish a communication between my pc and a special embedded module equipped with a philips usb controller. So I will be very interrested in having some information about the cvi abilities for usb communication.
Msp.
(3,284 Views)
Hello
CVI does not have any built in drivers for usb. Here is a KB that talks about that.
But CVI 6.0 does support activex and some device manufactureres provide an activex interface to their devices ( like a usb camera) that you can use to talk to it via usb. So you can use the ActiveX controller Wizard to generate a CVI wrapper for you to use. So if you can find something like that for you device, you should be all set.
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,284 Views)
(3,284 Views)
