LabWindows/CVI
user signal simulator
I want to create a function to simulate a sinusoid waveform, modulated by another signal. and then I want to use LabView's FFT to analyse it to see the frequence spectral. How to implement this use labVIEW.
If the signal is pure sinusoid waveform, that's easy. just use VI provided signal simulator. In my case I want to use a C code to generate the signal. Please give me some clue.
Thank you guys
(2,865 Views)
CVI includes the ANSI C sin function. The input is in radians.
Use a loop if you want to create a array of data.
#define PI 3.14159265
int numberSteps = 100;
int amplitude = 1;
int i;
double *sineWave;
sineWave = malloc (sizeof(double) * numberSteps);
for (i=0; i < numberSteps; i++)
sineWave[i] = amplitude * sin(i*2*PI/numberSteps);
The CVI Advanced Analysis Library also includes the following function which does some of the work for you.
int SineWave (int n, double amp, double f, double *phase, double x[]);
(2,855 Views)
