LabWindows/CVI
using PostDelayedCall how do I get the value passed through void *callbackData?
Can anyone tell me how to get the data passed through void *callbackData?
The code below, panel_ptr has the correct address but always contains zero.
void CVICALLBACK value_changed (void *callbackData)
 int* panel_ptr;
 panel_ptr = callbackData;
 calculate_new_value (*panel_ptr);
int panel;
panel = 2;
PostDelayedCall (value_changed, &panel, 0.2);
(3,147 Views)
Accepted by JPS_CSE
The problem in using callbackData parameter is that if it is a pointer, it must be a pointer to something that is still valid at the moment the callback executes. That is to say, you cannot pass the pointer to a local variable in callbackData since when the callback executes the pointer is no more valid. You can pass its value, instead, this way:
...SomeFunction ( )
  int panel;
  panel = 2;
  PostDelayedCall (value_changed, (void *)panel, 0.2);
  int     panel_ptr;
  panel_ptr = (int)callbackData;
  calculate_new_value (panel_ptr);
  return;
There are a lot of discussions on the forums about callbackData parameter that you may wnat to read.
(3,141 Views)
