LabWindows/CVI
viPrintf get parameter
I must write a GPIB command viprintf(),and the parameter get from user. the bleow useing viPrintf is right?
 if(InstrumentName_status=viPrintf(instrSession,"TPCSTEMP",stepsize,"\n":smileywink:<0)        //is right to use
        return InstrumentName_status;
there "TPCSTEMP" is a GPIB command ,stepsize is a parameter which ueser define .
and this is not main function,just a son function as a DLL document!
  thank you!
(4,329 Views)
Accepted by sean_tan
Yes I think the return code (VISA status code) will be stored in InstrumentName_status, but this code writing is not good. Ideally storing the return value to a variable and IF condition statement must be separated.
InstrumentName_status = viPrintf(instrSession,"....");
if( InstrumentName_status < 0 ) {
Plus, this viPrintf call does not reflect the given parameter because there is no "%" identifier. You should write as
InstrumentName_status = viPrintf(instrSession,"TPCSTEMP %d\n", (int)stepsize);
(4,312 Views)
thanks I know, I forgot d%.thanks caution!
(4,308 Views)
