Hi, I am having a similiar problem. I am using a Temptronic Thermostream TP04300A. The viRead command is timing out when performing queries of the instrument. If I step through the TestStand sequence, then the timeout does not occur, but when running at full speed the timeout occurs. So, I added some delays in the code, but this did not solve the problems. Any suggestions would be appreciated.
