LabWindows/CVI
virtual comport auto detect
HI
I am trying to comport auto detect,
i am uisng  status = viFindRsrc (defaultRM, "ASRL[0-9]*::?*INSTR", &find_list, &retCnt, instrDesc);  funtion  to detect  port , but its working  upto port  9  after 9 it not detecting  correct one . please give an idea how  tp slove this  issue.   ( comport  may be  1 to  255).
  thanks
Message 1 of 39
(7,134 Views)
@patil1983 wrote:
HI
  thanks
That's because you are telling it to look for com ports 0-9.
Message 2 of 39
(7,120 Views)
nyc, doesn't the * after the [0-9] mean zero or more occurrences of the preceding character or expression?
'or more' should include ports 10, 100, ..., no?
Message 3 of 39
(7,115 Views)
I am no regular expression expert.
the [0-9] means one digit 0 ... 9
the * means 0 or more times
Message 4 of 39
(7,114 Views)
so this means that 'That's because you are telling it to look for com ports 0-9.' is not correct... it should also find ports with numbers larger than 9...
Message 5 of 39
(7,110 Views)
I am not sure where the OP got his example code from.
The LabVIEW example VI at https://forums.ni.com/t5/Example-Code/Obtaining-a-List-of-Only-the-COM-Ports-as-VISA-Resource-Names/...   uses the expression ASRL?*::INSTR  which is very similar to what I used to find my USB scope.
It doesn't look like it is a real regular expression.
According to the LabVIEW Help,
  ?   matches any one character
  *  matches any 0 or more occurences of the preceding character or expression.
 [list]   matches any one character from the enclosed list. You can use a hyphen to match a range of characters
Message 6 of 39
(7,105 Views)
No, if it was a regular expression it will NOT find numbers greather than 9.
I suggest that you look up what [0-9] actually means for a true regular expression.
Brackets means a list and with the hyphen, you are looking 0 or 1 or 2 or 3 or 4 or 5 or 6 or 7 or 8 or 9.
That is it.
Message 7 of 39
(7,105 Views)
if you say so...
all I can tell is that viFindRsrc ( resource_manager_handle, "ASRL[0-9]*::?*INSTR", &find_handle, &return_count, instrument_descriptor ); does find all my serial ports, and I do have more than 30 Smiley Wink
Message 8 of 39
(7,090 Views)
Findind the correct search expression can be a challenge!
If I search with "ASRL[0-20]*::?*INSTR" function fails to recognize port 4, while "ASRL[0-24]*::?*INSTR" finds it; "ASRL[0-256]*::?*INSTR" fails too Smiley Surprised
However, the expression in brackets is not a simple list, since even "ASRL[0-4]*::?*INSTR" finds port 10 (for what is worth, "ASRL[1-4]*::?*INSTR" doesn't locate port 10).
I am not an expert on Visa and even less on regular expressions, but it seems to me that "ASRL?*INSTR" as mentioned before should be the best search string. Next he will need to discriminate the parallel port if it exists in the system, which is counted too by the call.
Message 9 of 39
(7,089 Views)
Roberto, I would assume that [0-2]* means 0,1,2,00,01,02, ... and accordingly it will not find port 4. The same is true for [0-256]*.
And, for the same reason, ASRL[0-4]* finds port 10 because 0-4 includes 0 and 1, and * means repetitive.
Message 10 of 39
(7,090 Views)
