LabWindows/CVI
virtual comport auto detect
I'm not sure how to interpret "0-24": the hiphen should mean "from x to y" but while I understand how it works with single digits, I am a bit lost when dealing with two digits. Does it mean that it will find port 24 and 240 only? Will it find port 204?
Message 11 of 39
(3,247 Views)
@Wolfgang wrote:
if you say so...
all I can tell is that viFindRsrc ( resource_manager_handle, "ASRL[0-9]*::?*INSTR", &find_handle, &return_count, instrument_descriptor ); does find all my serial ports, and I do have more than 30 Smiley Wink
Then you'll have to explain to the OP why it doesn't work for him.
Message 12 of 39
(3,242 Views)
http://www.regexr.com/  is a very good website
Message 13 of 39
(3,243 Views)
ah why, my code is working fine Smiley Happy
Personally I think that the original post should provide some more details for better help, such as VISA version, a screen shot of MAX showing the serial port configuration (does he really have 255 serial ports?), the sample code and the respective return values for port 1 - 10...
Message 14 of 39
(3,231 Views)
My understanding is different (but can be wrong, of course)
from the help: [list] :  Matches any one character from the enclosed list
To me 'any one character' means that it matches single characters, not numbers, so in my understanding 0-24 is interpreted as 0-2 and 4, i.e., 0, 1, 2, 4
[0-24]* thus should find both 24, 240, 204, but I do not have that many ports to verify Smiley Happy
At least it would explain your finding why ASRL[0-20]*::?*INSTR" fails to recognize port 4, in my understanding it will only search for port numbers 0, 1, 2, 10, 11, 12, 20, 21, 22, 100, 101, 102,...
I agree that a suitable example (in the documentation) would be useful.
Message 15 of 39
(3,230 Views)
As far as I can understand I second your opinion_ 0-24 means "0 to 2 AND 4" so it detects port 4, 14 and 24 but not port 3, 24, 36...
It would be interesting to see MAX configuration in patil PC: if some port is not recognized there it won't be listed from viFindRsrc. Nevertheless he should be able to interactively create in nmAX the port(s) not listed, and see them in CVI after thet.
Message 16 of 39
(3,227 Views)
hi,
Thanks to all  for reply.
yes   i tried all d way  but  its  detecting only  upto o-9.
Please if any one have  valid woeking  code ,please share it . It helps me lot .
Thnak you .:)
Message 17 of 39
(3,220 Views)
  1. Are ports >10 listed in MAX (MEasurement and Automation Explorer)? If not, can you try adding them manually? Then viFindRsrc should find them.
  2. You could try using the dll published by msaxon: it does not make use of VISA, just SDK calls
Message 18 of 39
(3,209 Views)
HI
Thanks for reply .
Com 10 is showing in MAX (MEasurement and Automation Explorer), where i add/check list of  all port .
Message 19 of 39
(3,206 Views)
hi
I still struggling in this issue, please give me proff solution .
i tryed all d way but its not working properly . please give me solution .
thanks
Message 20 of 39
(3,140 Views)
