voice recognition
im getting this error    1>c:\documents and settings\z1083774\desktop\keith_voice\keith_voice\keith_voice\keith_voice.h(58) : fatal error C1004: unexpected end-of-file found
#include <atlcom.h>
#else
#define KEITH_VOICE_API __declspec(dllimport)
#define _ATL_APARTMENT_THREADED
#include <atlbase.h>
//You may derive a class from CComModule and use it if you want to override something,
//but do not change the name of _Module
extern CComModule _Module;
#include <atlcom.h>
//#ifdef
#ifdef __cplusplus
extern "C" {
#include <atlcom.h>
    class KEITH_VOICE_API CKEITH_VOICE {
public:
    CKEITH_VOICE(void);
    // TODO: add your methods here.
extern KEITH_VOICE_API int nKEITH_VOICE;
KEITH_VOICE_API int fnKEITH_VOICE(void);
// all your function prototype go here
// end of extern C block if a C++ compiler is used
#endif __cplusplus
Message 11 of 20
(2,665 Views)
Darnell:
Whenever you get an unexpected end-of-file found message from a compiler, the first thing to check is your block constructs to make sure you have matching {}.
In the code you posted, you have two opening braces {, but only one closing brace }.
When you're using the #ifdef __cplusplus statement, you don't typically include a whole block of code, you just wrap the extern "C" statement, and separately its closing brace.  Check the examples in the links I posted earlier to see how this is done.
As I also mentioned earlier, you don't want to declare C++ code as extern "C".  It doesn't make any sense to declare a class extern "C" as you seem to be doing.  The only things you want to extern "C" are your wrapper functions, as I suggested earlier.
Message 12 of 20
(2,657 Views)
im still getting the same thing now, when i  put the close braces.
and also when you just export your function, do you mean the function call or the prototypes
where to put the headerfiles, do i put them in the wrapper?
#ifdef KEITH_VOICE_EXPORTS
#define KEITH_VOICE_API __declspec(dllexport)
#include <atlcom.h>
#else
#include <atlcom.h>
//#ifdef
#ifdef __cplusplus
extern "C" {
#include <atlcom.h>
#endif __cplusplus
Message 13 of 20
(2,649 Views)
Darnell:
You're still not using  extern "C" as I described in the links I posted earlier.  Go back and look at those links.
#if is different than if() in that you need an #endif for each #if.
You have two #if's and only one #endif.  So the compiler gets to the end of the file still looking for another #endif that's not there.
Use braces to block the statements you want affected by #if.
Here is some more information on exporting functions from a Viusal Studio DLL:
http://msdn.microsoft.com/en-us/library/16ya5xae(VS.80).aspx
The wrapper functions will be defined in your CPP files.  You will export the functions (see the MSDN link above), and include the prototypes of the exported functions in a .h file that your CVI program will #include.
Message 14 of 20
(2,639 Views)
okay i started all over to make sure i was following what you were doing, i had to start over from scratch,
check this see if this is what you are talking about.
Message 15 of 20
(2,629 Views)
I think im almost there, i have everything you say to do, now for im getting a alot of errors pertaining to one header file
you can check the project thats in CVI that i attach
Message 16 of 20
(2,625 Views)
Darnell:
Please remember that this is a LabWindows/CVI forum, not a C++ forum.
I'm not sure what you would like us to do when you post a 3Meg project and say "check this see if this is what you are talking about".  Do you have a specific question?
How can I know where to start when you say "im getting a alot of errors pertaining to one header file" ?  What errors?  What header file?
Your best chance for success on this forum is if you ask a specific question about CVI.
Message 17 of 20
(2,619 Views)
i got the c++ part right it just when i get to cvi to call the functions from c++ , i get errors, im going to post a screen shot of the erros i get thats better.
OK CHECK THE ATTACHMENTS ,I POSTED THE ERRORS IN SCREEN SHOTS, AND THEN THE C++ C FILE AND THE HEADER FILE IM GOING TO COPY AND PASTE
 #ifndef _KEITH_SPEAK_H_
#define _KEITH_SPEAK_H_
//#include <iostream>
#define DLL_EXPORT
#define KEITH_FUNCTION_VOICE __declspec(dllexport)
extern int __cdecl FUNCTION_VOICE(void);
#ifdef __cplusplus
extern "C" {
#endif
KEITH_FUNCTION_VOICE int FUNCTION_VOICE (void)
// prototypes of functions exported for CVI to call
#ifdef __cplusplus
#endif
Message 18 of 20
(2,617 Views)
darnell wrote:
"im getting this error    1>c:\documents and settings\z1083774\desktop\keith_voice\keith_voice\keith_voice\keith_voice.h(58) : fatal error C1004: unexpected end-of-file found"
this is not a visual studio forum... but sometimes (often) this error is related to precompiled headers, either due to a badly formed project or a file you deleted (stdafx.h ?): turn off precompiled headers in the project options or recreate your project from scratch (or learn how precopiled headers work and correct the real problem)
Message 19 of 20
(2,608 Views)
Although it is in LabVIEW you may want to consider taking a look at something I created, "LabVIEW Speak"
The entire code base is open and I'm using the .NET API so perhaps you can see how I accomplish some of these actions that you're trying to work through.
Article Posting: http://zone.ni.com/devzone/cda/pub/p/id/909
Getting Started Videos: http://decibel.ni.com/content/groups/labview-apis/blog/2009/11/19/labview-speak--programming-lv-thro...
This program does a variety of things out of the box, but is also intended to act as an abstraction layer between the user and the Microsoft .NET speech API.
I haven't read the whole thread, but this tool allows you to make a command set array of strings, send it to the LVSpeak Engine, and receive LV events when one of the commands is detected.
-Norm
Message 20 of 20
(2,427 Views)
