LabWindows/CVI
want to build application for xp
i have version of CVI/LabWindows 4.0.1.....
i build a software distribution kit for my app but get an error in installation under xp environment. the error is as follows: "insufficient disk space to install application. The directory must have more than 0 bytes to install.." What do i have to do to get my application to install and run under Windows XP?
Is there a patch that will fix it or do I have to get a full upgrade...?
chrish
(2,936 Views)
Hello
CVI 6 is the version that has been tested with XP. There were alot of changes made to the OS, and CVI 4 came out way before the OS even existed. You would need to have a full upgrade if you intend to develop applications for XP
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(2,936 Views)
I think this is a drive size problem rather than an XP problem. The installer with CVI 4 does not understand drive sizes bigger than a certain amount.
I recall this being discussed on the CVI mailing list an age ago; but sorry, I cannot recall whether there was a fix for it. You may want to try asking on the mailing list if you get no joy here, since there are participants there who do not use this forum.
Martin.
Martin
Certified CVI Developer
(2,936 Views)
