LabWindows/CVI
what are valid values for a bitmapid ?
Hello all,
Question: what are valid values for a bitmapid ?
I am using CVI 6
I am building a programme with many calls to GetCtrlDisplayBitmap(panelid, controlid, 0, &bitmapid);
This call is part of some preparation that also includes several memory allocations (malloc).
So the organize the cleanup, I initialize variables to a non-valid value, and check these variables during cleanup. The original erroneous code is shown below.
int status;
int bitmapid = -1;
unsigned char *allbits = NULL, *dbit=NULL;
status = GetCtrlDisplayBitmap(panelid, controlid, 0, &bitmapid);
if (status < 0) goto CleanUpMemory;
status = AllocBitmapData (bitmapid, NULL, &dbit, NULL);
allbits = malloc(allsize);
if (allbits == NULL) goto CleanUpMemory;
CleanUpMemory:
if (dbit != NULL) free (dbit);
if (allbits != NULL) free (allbits);
if (bitmapid <= 0) DiscardBitmap (bitmapid);
When I noticed a memory leak, I searched for the cause.
I found large negative values for the bitmapid e.g. -366280272
So I repaired this code with
int bitmapid = 0;
if (bitmapid != 0) DiscardBitmap(bitmapid);
But this is only valid if 1) a valid bitmapid is never zero, and 2) GetCtrlDisplayBitmap does not change this value to a random number when an error occurs.
So my question is: are there values for a bitmapid that never occurs, so that I can use this as a check if freeing memory is needed ?
Regards, Jos
(3,407 Views)
Sorry about an important typo in the source above. The source code - that got rejected - is of course:
if (bitmapid >= 0) DiscardBitmap (bitmapid);
Regards, Jos
(3,403 Views)
I think in practice the bitmap ID will always be a large negative number, however checking against zero is fine and I would say the correct thing to do. Zero will never be a valid bitmap ID.
-alex
(3,393 Views)
Jos,
Large negative values are normal for a bitmap id, if you are using signed integers. It will be more meaningful if you store the id in an unsigned integer, and also if you view it as a hexadecimal number.
In any case, you're safe in assuming that a valid bitmap id cannot be 0. So you should feel free to initialize your variable to 0, and then discard it if it is anything other than 0.
Luis
NI
(3,392 Views)
