Hello all,
Question: what are valid values for a bitmapid ?
I am using CVI 6
I am building a programme with many calls to GetCtrlDisplayBitmap(panelid, controlid, 0, &bitmapid);
This call is part of some preparation that also includes several memory allocations (malloc).
So the organize the cleanup, I initialize variables to a non-valid value, and check these variables during cleanup. The original erroneous code is shown below.
int status;
int bitmapid = -1;
unsigned char *allbits = NULL, *dbit=NULL;
status = GetCtrlDisplayBitmap(panelid, controlid, 0, &bitmapid);
if (status < 0) goto CleanUpMemory;
status = AllocBitmapData (bitmapid, NULL, &dbit, NULL);
allbits = malloc(allsize);
if (allbits == NULL) goto CleanUpMemory;
CleanUpMemory:
if (dbit != NULL) free (dbit);
if (allbits != NULL) free (allbits);
if (bitmapid <= 0) DiscardBitmap (bitmapid);
When I noticed a memory leak, I searched for the cause.
I found large negative values for the bitmapid e.g. -366280272
So I repaired this code with
int bitmapid = 0;
if (bitmapid != 0) DiscardBitmap(bitmapid);
But this is only valid if 1) a valid bitmapid is never zero, and 2) GetCtrlDisplayBitmap does not change this value to a random number when an error occurs.
So my question is: are there values for a bitmapid that never occurs, so that I can use this as a check if freeing memory is needed ?
Regards, Jos
