LabWindows/CVI
what is the seconds of first call to Timer()
in help document of Timer() : "Returns the number of seconds elapsed since the first call to Timer, Delay, or SyncWait, or the first operation on a timer control. The value is never reset to zero except when you restart the program. " in my code,after restart the program,sometimes the first call to Timer(),return 0 second; and sometimes,return above 0 seconds,such as 40 seconds. why?
(2,400 Views)
Accepted by topic author winter1970
It depends on when it hits the breakpoint.
If it hits immediately, then you should around 0.
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
(2,363 Views)
thank you. what's the meaning of the breakpoint you said ? in my code ,i have not set any breakpoint.
(2,330 Views)
