LabWindows/CVI
which library defines SaveBitmapToJPEGFile()
I'm working on a years-old project which distributes a few of the cvi libraries.  I now need to build in a new feature which was developed by my colleague who is not currently available to help.
I'm getting an "unresolved externals" link error for a call to SaveBitmapToJPEGFile().  I have CVI 2010, so I'm guessing the problem is that one of the cvi libraries in the project is old and needs to be updated.  I know that SaveBitmapToJPEGFile() is declared in userint.h, and I have that file updated.  But which *.lib file is it defined in?  (I'm building in MS Visual Studio 6.0, in case that matters.)
Thanks in advance ...
(3,488 Views)
You will need the cvirt.lib included in your project to resolve this symbol.
(3,482 Views)
Thanks.  Can you tell me which is the earliest version we can use?  This is a very established (read "old") project, and I want to minimize the possibility of new stuff which may be incompatible with our existing old stuff.
(3,478 Views)
Accepted by B.Anderson
You can always find the earliest version that a function was supported in from the bottom of the help documentation for that function. This particular function is supported in CVI 7.1 and later.
http://zone.ni.com/reference/en-XX/help/370051T-01/cvi/uiref/cvisavebitmaptojpegfile/
(3,468 Views)
