LabWindows/CVI
why the .exe file can run in WinXP OS but can't run in Win2000?
The .exe file is built by LabWINDOWS.
(3,247 Views)
Can you provide some additional information on the behavior you are seeing? Which version of CVI was the application built with? What error message do you receive when you run it in Windows 2000? If the application uses hardware drivers or other software, is this software installed on the Windows 2000 machine? What kind of application is being run in the executable?
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(3,233 Views)
LabWINDOWS7.0.Yes, I drive the sound card in the program.
(3,207 Views)
Hello again,
What error message do you receive when you run it in Windows 2000? Do you have the appropriate drivers on your Window 2000 machine including the CVI runtime engine?
Thanks.
Wendy L
(3,181 Views)
