LabWindows/CVI
winsock gethostbyname() behaves different when debugging
I'm testing porting a library into NI CVI 9.0 and I've just built a very simple DLL to exercise one function from WinSock on XP SP3. When I run the executable from the command line, gethostbyname() returns correct data. When I'm debugging using the CVI 9.0 IDE, gethostbyname() returns -1.
I'm not sure where to start as I'm not sure why there should be a difference.
This is compiled as a DLL:
#include <winsock.h>
#define LIBAPI __declspec(dllexport)
LIBAPI int WINAPI SYScurrentHost(char *buff, size_t buflen) {
    result = gethostname(buff, buflen);
    if (result) return result;
    return strlen(buff);
The main() that calls SYScurrentHost when run (as a console application) from the console returns the actual host name. But when I put a breakpoint in SYScurrentHost(), result is -1 indicating an error. The LIB file for wsock32.lib is found from "C:\Program Files\National Instruments\CVI90\sdk\lib\msvc\wsock32.lib" which I had to add manually (somehow I have the feeling that this shouldn't be needed, but I had linker errors without it).
Jason.
(3,744 Views)
Accepted by jcurl
Before making any calls to Winsock, you must initialize the library by calling WSAStartup. You'll notice that if you call WSAGetLastError after gethostname returns -1, it returns WSANOTINITIALISED. It appears that creating a command window must automatically initialize Winsock, though I could not find any documentation to back this up.
Mert A.
(3,733 Views)
