LabWindows/CVI
x-circle and r-circle Smith Chart color
I would like to customize the color of the Smith Chart, but I do not know which attribute I should modify ?
With the default setting colors, the x-circle and r-circle of the Smith Chart are plotted in blue. I would like to change these default colors to a specified color, wich I can modify by programing.
In other words, I would like to know which atributes of the graph which I should modify to set a specific color?( means the attribute to put in SetCtrlAttribute function to modify the x-cricle and r-circle colors of the Smtih Chart).
The background of this smith Chart is modified with ATTR_PLOT_BGCOLOR attribute, in which the default value is the gray. The ATTR_PLOT_BGCOLOR is attribute of a classical Graph, as the smith chart is obtained by converting this classical graph.
Thank you so much for your answer.
hapiest
(4,843 Views)
I would like to know if someone has a solution for the issue above I have posted?
hapiest
(4,808 Views)
Accepted by hapiest
Hello !
You can directly modify Intrument Driver for Smith Graph, in "smith.c" source code.
Directly by modifying a constant in the source code or create a function to have more flexibility
Jérôme Henrion | ONERA - Digital RF Engineer | CLA | CTA
(4,791 Views)
