LabWindows/CVI
xcopy without a command window....
I need to download from the network a folder, not always the same folder as this will hopefully be pragmatically controlled, along with its sub folders, if present.
As far as I can see the best option is xcopy, with its switches, or is there another option?
Err = system ("xcopy /S/Q/Y/R/K \\\\NW_Drive\\Test_Fol\\TestDataSource\\Rel\\TestCode\\*.* C:\\Test_Loc\\test\\SRM\\");
If it is to be xcopy can it be done without a command window or at least a small or minimized command window?
Thanks for the help
Simon
(4,569 Views)
Accepted by Srm27
You may want to explore LaunceExecutableEx possibilities, especially for its ability to hide the launched program window. Keep in mind that this is an asynchronous call, so if you want to survey the process you need to save the handle returned by the command and periodically check its state with ExecutableHasTerminated () function.
(4,567 Views)
Roberto,
Thanks, using LaunchExecutableEx did the job.
As the initial folder is small this copy happens quick.
For any thing bigger I will keep in mind to monitor with ExecutableHasTerminated.
Simon
(4,562 Views)
