Life Science
add a shift to graph
Dear all,
I am writing a program where i want to add a shift to the Plot.
I have a Graph whose Time Axis is from 0 to 100.
I want the Graph to start displayng from point 1, i.e adding a shift of 1 to the plot.
Now next plot i want to display from point 2, i.e adding a shift of 2 to the plot.
How can i achieve this ?
Ritesh
(11,812 Views)
(11,810 Views)
You can use the function Rotate 1D array to shift the array berfore ploting.
To change the X axis, you use property node to write new atributes.
RKO
(11,730 Views)
Please continue discussion in this thread only (as pointed out by mathan).
Keep one topic to a single thread in order to contain all discussion within the single thread.
(11,709 Views)
