Linux Users
Error 54 on Simple TCP Create Listener
I am getting an error 54 on a very simple TCP Create Listener function. Has anyone else experienced this behavior? Using Ubuntu 20.04.4 LTS with LabVIEW 2021 f2 (64-bit).
(3,863 Views)
Did you read the error message? We can't even tell from the blurry picture what's wired to where and what the values are.
Please attach your VI instead.
(3,845 Views)
I apologize for the low res image. I was simply creating a listener on port 502 to communicate via Modbus. I found the reason why I am receiving an error. Ports below 1024 are restricted on Linux/Unix as a general rule - only apps with root privileges can listen on those. Starting LabVIEW with sudo allowed me to use port 502.
(3,813 Views)
