Linux Users
IrqTimeoutWarning in Python function on Red Hat 8.6 while waiting on Irq from FPGA
I have  a complex application that involves LabVIEW under Linux, and accessing FPGA fabric via Python nodes. In the compiled LabVIEW application I get a warning that doesn't show up in the development environment. Since it is a benign warning and can be safely ignored (I expect the timeout), I don't want the message to show up in the terminal. I suspect I need to trap the warning in python, but I'm not sure why the warning should show up at all. How do I make the message go away?
The message:
/usr/local/lib/python3.6/site-packages/nifpga/status.py:69: IrqTimeoutWarning: Warning: IrqTimeout (61060) when calling 'NiFpgaDll_WaitonIrqs' with arguments:
  session: 0x1
  context: 0x1
  irqs: 0x400
  timeout ms: 0x32
  irqs asserted: 0x0
  timed out: 0x1
warnings.warn(warning)
Python code that I'm pretty sure caused the warning:
def WaitOnIRQ():
  global session
  timeout_ms = 50
  irq_num = [10]
  irq_status = session.wait_on_irqs(irq_num, timeout_ms)
  if irq_num in irq_status.irqs_asserted:
     session.acknowledge_irqs(irq_status.irqs_asserted)
  return(irq_status.timed_out);
Message 1 of 1
(2,321 Views)
