Linux Users
How to install NI-DAQmx 8.0.1 on Ubuntu 10.10 (Maverick Meerkat) 32 bit
I suppose you have a clean install with an updated kernel (2.6.35-27 in my case today)
Please make sure you do not have any comedi module/package installed/loaded in memory
If so, remove the comedi driver (until now I still don't have a "clean" way to do it. Any udev/comedi/2.6 kernel expert around?)
// Get and uncompress NI-VISA in your home directory
// Boot and open a console
cd
mkdir DAQmxInstall
cd DAQmxInstall
mkdir VISA
cd VISA
// Get NI-VISA 5.0 ISO on :
// https://www.ni.com/en/support/downloads/drivers/download.ni-visa.html#306106
// Open the ISO and copy nivisa-runtime-5.0.0f1.tar.gz locally
cp /media/NIVISA-Runtime500L/nivisa-runtime-5.0.0f1.tar.gz ./
tar -zxvf nivisa-runtime-5.0.0f1.tar.gz
// Get and uncompress NI-DAQmx in your home
cd ..
mkdir DAQmx
cd DAQmx
// Get NI-DAQmx 8.0.1 for Linux on
// http://joule.ni.com/nidu/cds/view/p/id/1194/lang/en
// Open the ISO and copy 2 files
cp /media/DAQmx8.0.1f0/nidaqmx-8.0.1f0.tar.gz ./
cp /media/INSTALL ./
tar -zxvf nidaqmx-8.0.1f0.tar.gz
cd ..
// Install the linux source code and needed tools
sudo su
ln -sf /bin/bash /bin/sh
apt-get install alien bum build-essential
apt-get build-dep --no-install-recommends linux-image-$(uname -r)
apt-get install linux-source
// Install NI-KAL
cd VISA/rpms
rm -rf *_64.rpm
alien -k --scripts nikali-2.0.0-f0.noarch.rpm
// Now we have nikali_2.0.0-f0_all.deb in the directory
dpkg -i nikali_2.0.0-f0_all.deb
cd /usr/local/natinst/nikal/bin
. nikaliInstallerUtility.sh
nikaliPostInstall
./updateNIDrivers
Reboot
// Open a console
sudo su
modprobe nikal
lsmod
// You should see nikal in the list
// Install DAQmx with the script
cd DAQmxInstall/DAQmx
./INSTALL --nodeps
// In my case I do not install anything for LV
// If the script reports error about NIKAL, don't worry.
Reboot
// Open a console
sudo su
cd /lib/modules/$(uname -r)/build/include/linux
ln -s ../generated/utsrelease.h
ln -s ../generated/autoconf.h
// Re-install NI-KAL
cd
cd DAQmxInstall/VISA/rpms
dpkg -P nikali
nikaliPostInstall
./updateNIDrivers
Reboot
// Open a console
lsmod | grep ni
// You should see something like
nimru2k               427897  1
nimxpk                 33632  0
nipxirmk              115030  1
nidimk                320599  5 nimru2k,nipxirmk
nimsdrk               231258  0
nidmxfk               373960  1 nimsdrk
nimxdfk               477896  5 nimru2k,nimsdrk,nidmxfk
nimstsk                78153  2 nimsdrk,nidmxfk
nimdbgk               360232  7 nimru2k,nimsdrk,nidmxfk,nimxdfk,nimstsk
niorbk                 95647  8 nimru2k,nipxirmk,nidimk,nimsdrk,nidmxfk,nimxdfk,nimstsk,nimdbgk
nipalk               1195435  14 nimru2k,nimxpk,nipxirmk,nidimk,nimsdrk,nidmxfk,nimxdfk,nimstsk,nimdbgk,niorbk
nikal                  57402  1 nipalk
// You should see your DAQ devices
nilsdev
// Let's make a test
cd /usr/local/natinst/nidaqmx/examples/ansi_c/AnalogIn/MeasureVoltage/Acq-IntClk
make
./Acq-IntClk
// What if the kernel is updated?
// NI-KAL must be re-installed and the others modules must be updated as well.
// Open a console
sudo su
cd
dpkg -P nikali
nikaliPostInstall
./updateNIDrivers
Regards, Philippe proud to be using LabWindows since version 1.2
(16,082 Views)
Thank you for this. I can get it to work up until the point of :
lsmod | grep ni
Nothing shows except nikali (which i have to modprobe every time to get it started)
Basically it will not create /usr/local/natinst/nidaqmx
Any feedback would be greately appreciated
(5,793 Views)
In my case nikal is the only kernel module generated/installed to /lib/modules/$(uname -r)/kernel/natinst. Moreover, nikal is not loaded by default (after reboot).  I see a problem with DAQmx installation part:
Installing NI-DAQmx for Linux Installer Distribution version 8.0.1f0...
Pre Installation ...............................
rpm: please use alien to install rpm packages on Debian, if you are really sure use --force-debian switch. See README.Debian for more details.
Error installing NI-DAQmx for Linux Installer Distribution 8.0.1f0.
Installer is aborted.
Regards
LAW
(5,793 Views)
Thanks for this explanation, but i have some problems :
I've got a kernel named linux-image-2.6.32-audithis,i've rename him to find him more easily in grub and for customize thiskernel.
But i don't find the folder generated for this part of script :
sudo su
Andwhen I look what there are in the folders ....../include/linux i findthis files(utsrelease.h and autoconf.h). So, this part is useless forme? Or not?
And more, when I do lsmod |grep ni, there are nikal and nipalk, not the others modules ...
Can you help me?
For information, the script ./INSTALL --nodeps works, there are no error.
Bark Ridley
(5,793 Views)
Thanks for posting! This has been extremely helpful.
However, I hit a problem when I try the command nilsdev - nothing appears, so it would seem that the driver is not recognizing the attached PCI card. However, the command lspci shows that a National Instruments card is connected.
Any help would be much appreciated.
Best,
Julie
(5,793 Views)
hello,i have the same problem, any suggestion would be much appreciated
(5,793 Views)
