Linux Users
there is nothing when i use lsmod | grep ni
hello,
when i installed DAQmx8.0.2 for LabVIEW8.6, my sysytem is ubuntu12.10. here is the result:
Installing NI-DAQmx for Linux Installer Distribution version 8.0.2f0...
Pre Installation .
Post Installation .
Pre Installation ...............................
Post Installation ...............................
Updating modversions database to include newly installed drivers...
FOR PATENTS COVERING NATIONAL INSTRUMENTS PRODUCTS, REFER TO
THE PATENTS.txt FILE ON /usr/local/natinst/LabVIEW-8.6/DAQmxInstall/DAQmx AND/OR
www.ni.com/patents
NI-DAQmx for Linux Installer Distribution Installation completed successfully.
do i installed successfully?
and when i run LabVIEW8.6,there is no daq module.
when i use the commend lsmod | grep ni, however,there is nothing. only when i use the commend modprobe nikal,there is the nikal.
any suggestion will be appreciated, thanks.
Message 1 of 1
(3,409 Views)
