Linux Users
Kernel panic while loading NI hardware PXIe-6366.
Greetings!
I have two NI cards (PXIe-6366 and PX-6132) inserted in a chassis PXIe-1073. This chassis is connected by a PCIe 8361 card with the CPU on which I am using RHEL 7.6. On my PC I have installed DAQmx 18.1 for Linux and LabVIEW 2018 for Linux.
Now everytime I boot up my machine into the standard kernel (where I have installed NI softwares) I get this error of which I have attached the image. This error is present only when I have connected NI hardware, when I remove  hardware and boot into standard kernel it is working fine.
P.S.- I am using this chassis with the two cards in it on windows machine and it is working fine.
(2,897 Views)
Make sure you have the latest version of the drivers.  NI recently updated the 2018 driver stack to work better with the kernel in RHEL 7.6.  Try the following:
yum --disablerepo="*" --enablerepo="ni-software-2018" update
(2,890 Views)
