Linux Users
PCIe-6341 under openSUSE Leap 15.0 with DAQmx 18.1 - Fails to load Dev1 with error -50528
Dear all,
I'm new to this forum, so I'm sorry if I missed something obvious. I'm trying to get a PCIe-6341 to work under openSUSE Leap 15.0. I'm using the
https://download.ni.com/ni-linux-desktop/2018.07/rpm/ni/Leap42.3 repository. That seems to work (installs/updates without errors), but I get a "Failed to Load" error when trying to use a PCIe-6341 card (see nilsdev output below). The too new SuSE version might be the problem, but I'd like to know what this '-50258' error means before I go through the hassle of installing (a soon to be obsolete) older linux os.
Does anyone have any suggestions?
Thank you!
Jacco
##### nilsdev --verbose
Dev1 [Failed to Load]
  BusType: PCIe
  DevInitStatus: -50258
  DevSerialNum: 0x1E011DB
  PCI.BusNum: 0x84
  PCI.DevNum: 0x0
  ProductNum: 0x742BC4C4
  ProductType: PCIe-6341
(3,560 Views)
I'd bet the kernel modules have failed to load.  Does 'lsmod' show any loaded NI drivers?
(3,555 Views)
Thanks for the reply. If anything there are way too many NI drivers, see below.
##### lsmod
Module                  Size  Used by
nixsrk               3379200  0
niwfrk               1048576  0
NiViPciK               77824  1
nisync6674           5664768  0
niswdk               2551808  0
nissrk               2646016  0
nitiork              1445888  2 nissrk,nixsrk
nismbus               311296  0
nismbusw              126976  1 nismbus
nisldk               1183744  0
niserial               16384  0
niscdk               1392640  1 niswdk
NiRioSrv              925696  0
niriomtk              335872  0
niriochinchk          458752  0
nipxiocp               77824  0
nipxim2                77824  0
nipxigpk               28672  0
nipxifpk               69632  0
nipxirmk              303104  3 nipxigpk,nipxifpk
nipxicidk             720896  0
nimxik                110592  0
nimsdrk               409600  1 nisldk
nihsdrk              5554176  0
nihorbrk             2727936  0
niesrk               1167360  0
nidsark              1744896  0
nistcrk               221184  4 nissrk,niesrk,nidsark,niwfrk
nistc2k               331776  5 nissrk,niesrk,nistcrk,nidsark,niwfrk
nicondrk             1802240  0
nicntdrk              212992  0
nicmrk               5812224  0
nicmmk                 98304  0
ni5170k               753664  0
ni5164k               811008  0
nistreamk             135168  5 niriochinchk,ni5170k,ni5164k,nihsdrk,NiRioSrv
nibds                  69632  5 niriomtk,niriochinchk,ni5170k,ni5164k,NiRioSrv
ni5110k             14200832  0
ni488k                208896  0
ni408x_driver        1552384  0
ni1045tr              110592  0
niraptrk             4358144  1
nistc3rk             2457600  4 nihorbrk,niraptrk,nicondrk,nicmrk
nicdcck               122880  1 nistc3rk
nifslk                348160  2 nistc3rk,nixsrk
nisdigk               741376  6 nihorbrk,nissrk,niraptrk,niesrk,nixsrk,nicondrk
nilmsk                724992  9 nitiork,nissrk,niesrk,nistc3rk,nistcrk,nixsrk,nidsark,nicondrk,niwfrk
nicdrk                512000  11 nitiork,nihorbrk,nissrk,niraptrk,niscdk,niesrk,nisdigk,nixsrk,nicondrk,niswdk,niwfrk
nidmxfk               598016  18 nitiork,nihorbrk,nissrk,niraptrk,niscdk,niesrk,nisdigk,nistc3rk,nistcrk,nixsrk,nihsdrk,nicdrk,nilmsk,nicondrk,nicmrk,nimsdrk,niwfrk
nimru2k               757760  20 nitiork,nihorbrk,nissrk,niraptrk,niscdk,niesrk,nisdigk,nistc3rk,nisldk,nistcrk,nixsrk,nidsark,nihsdrk,nicondrk,niswdk,nicmrk,niwfrk
nidimk                364544  20 nitiork,nihorbrk,nissrk,niraptrk,niscdk,niesrk,nisdigk,nistc3rk,nipxirmk,nixsrk,nidsark,nihsdrk,nicondrk,niswdk,nimru2k,niwfrk
nimxdfk               540672  29 nicdcck,nitiork,nihorbrk,nissrk,niraptrk,niscdk,niesrk,nisdigk,nistc3rk,nipxigpk,nisldk,nistcrk,nixsrk,nidsark,nidmxfk,nipxifpk,nihsdrk,nicdrk,nilmsk,nicondrk,niswdk,nicmrk,nimru2k,nimsdrk,niwfrk
nimdbgk               421888  33 nicdcck,nitiork,nihorbrk,nimxdfk,nissrk,niraptrk,niscdk,niesrk,nisdigk,nistc3rk,nipxigpk,nipxirmk,nisldk,nistcrk,nixsrk,nistc2k,nidsark,nidmxfk,nifslk,nipxifpk,nihsdrk,nicdrk,nilmsk,nicondrk,niswdk,nicmrk,nimru2k,nimsdrk,ni
wfrk
niorbk                106496  29 nicdcck,nitiork,nihorbrk,nimxdfk,nissrk,niraptrk,niscdk,niesrk,nisdigk,nistc3rk,nipxigpk,nipxirmk,nisldk,nistcrk,nixsrk,nidimk,nidsark,nidmxfk,nipxifpk,nihsdrk,nicdrk,nimdbgk,nilmsk,nicondrk,niswdk,nicmrk,nimru2k,nimsdrk,ni
wfrk
fuse                  118784  3
nipalk               1146880  40 nicdcck,nitiork,niorbk,nihorbrk,nimxdfk,nissrk,niraptrk,niscdk,niesrk,nisdigk,nistc3rk,NiViPciK,ni488k,nipxigpk,nipxirmk,nisldk,nistcrk,nixsrk,nistc2k,nidimk,nidsark,nidmxfk,nifslk,nipxifpk,nihsdrk,nicdrk,nimdbgk,nilmsk,nic
nikal                 114688  52 nicdcck,ni5110k,nitiork,niorbk,nihorbrk,nimxdfk,niriomtk,niriochinchk,nissrk,niraptrk,niscdk,niesrk,nisdigk,nistc3rk,nipxim2,ni5170k,nipxicidk,nipxigpk,nicntdrk,nismbus,nipxirmk,ni1045tr,nisldk,ni5164k,nistcrk,nixsrk,nipxio
cp,nistc2k,nidimk,nidsark,nidmxfk,nipalk,nifslk,nicmmk,nipxifpk,nihsdrk,nicdrk,nismbusw,nimxik,nimdbgk,nistreamk,nilmsk,nicondrk,niswdk,nicmrk,nibds,nimru2k,nimsdrk,ni408x_driver,NiRioSrv,niwfrk,nisync6674
af_packet              49152  0
iscsi_ibft             16384  0
iscsi_boot_sysfs       16384  1 iscsi_ibft
msr                    16384  0
intel_powerclamp       16384  0
xfs                  1380352  1
libcrc32c              16384  1 xfs
coretemp               16384  0
kvm_intel             241664  0
ipmi_ssif              28672  0
kvm                   708608  1 kvm_intel
igb                   245760  0
joydev                 24576  0
ptp                    20480  1 igb
pps_core               20480  1 ptp
iTCO_wdt               16384  0
iTCO_vendor_support    16384  1 iTCO_wdt
ioatdma                61440  0
irqbypass              16384  1 kvm
gpio_ich               16384  0
lpc_ich                28672  0
ipmi_si                65536  0
i5500_temp             16384  0
i2c_i801               32768  0
dca                    16384  2 ioatdma,igb
shpchp                 40960  0
ipmi_devintf           20480  0
ipmi_msghandler        49152  3 ipmi_ssif,ipmi_devintf,ipmi_si
i7core_edac            28672  0
pcspkr                 16384  0
acpi_cpufreq           24576  1
crc32c_intel           24576  1
button                 16384  0
hid_generic            16384  0
usbhid                 57344  0
mgag200                53248  1
i2c_algo_bit           16384  2 mgag200,igb
drm_kms_helper        200704  1 mgag200
syscopyarea            16384  1 drm_kms_helper
sysfillrect            16384  1 drm_kms_helper
sysimgblt              16384  1 drm_kms_helper
fb_sys_fops            16384  1 drm_kms_helper
serio_raw              16384  0
ttm                   114688  1 mgag200
uhci_hcd               49152  0
ehci_pci               16384  0
ehci_hcd               94208  1 ehci_pci
drm                   438272  4 mgag200,ttm,drm_kms_helper
mpt3sas               274432  3
drm_panel_orientation_quirks    16384  1 drm
usbcore               286720  4 usbhid,ehci_hcd,uhci_hcd,ehci_pci
raid_class             16384  1 mpt3sas
scsi_transport_sas     45056  1 mpt3sas
sg                     45056  0
dm_multipath           36864  0
dm_mod                139264  1 dm_multipath
scsi_dh_rdac           16384  0
scsi_dh_emc            16384  0
scsi_dh_alua           20480  0
(3,549 Views)
Yep, color me wrong on that guess!
(3,544 Views)
FWIW, I did install openSUSE Leap 42.3 on another partition in this system and that did 'solve' the issue. It's still not clear what the actual problem is under Leap 15.0 though.
(3,532 Views)
