Linux Users
Labview 2016 using Centos7
Hi All,
I have an interesting issue if I open LabVIEW and then open a vi everything works great. However if I try to open a vi from my file browser using "Open with:" Labview2016 32bit or Labview2016 64bit nothing happens at all. Same thing if I just double click on my vi's icon. I am using MATE as my desktop. Anyone else having this issue?
Dave
(4,601 Views)
I had (and still have) the exact same issue. LabVIEW 2018 on CentOS 7 with GNOME.
(4,578 Views)
Same here, LabVIEW 2018 CentOS 7.6.
Also, sometimes clicking the VI on the tool bar to open the front panel or block diagram does not work as well.  I suspect the OS more than LabVIEW in this instance.
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(4,558 Views)
I solved the issue this weekend. Go to /usr/share/applications you will find a Labview20xx.desktop file you will need to edit the line that starts with EXEC. find where you labview executable is located and replace everything on that line except %F with the complete path to the executable also make sure the line starts with EXEC=/. If labview is no longer on your "Open With" list then you made a mistake in editing your desktop file. I am at work now and don't actually have access to my LabVIEW installation to provide more detail. I will follow up tomorrow and provide the desktop file that I used.
Good Luck,
Dave
(4,548 Views)
Good Luck,
Dave
The exec line should look something like this:
Exec=/usr/local/natinst/LabVIEW-2016/labview %F
(4,536 Views)
