Linux Users
Where can I get driver installer for NI-DAQmx NI-6509 model - for Redhat 6.9
Hi NI Team,
Can someone help me advise  where can I get a driver installed needed for my NI-DAQmx model NI-6509 card. I've opened a  site but I only found version 15.0 for Linux Redhat 6.9. Your help is a greatly approciated.
thanks,
Dexter
(3,092 Views)
I am also try to get the NI-DAQmx base 15.0 for linux and the NI VISA for linux. But it's no way to get from NI download page.
if anybody no any information, please contact me.
Best wishes,
Zhongliang
(3,074 Views)
@Dex123 wrote:
Hi NI Team,
thanks,
Dexter
Use the 2018 stack.
Install the RPM for RHEL6, then you should be able to just "yum install ni-daqmx".
(3,061 Views)
Thanks for the info. I 'll try this.
(3,051 Views)
For more information, please check the documentation below:
  1. Installation procedure: http://www.ni.com/product-documentation/54754/en/
  2. NI MAX is not installed on Linux, use the tool here: https://www.ni.com/en/support/documentation/supplemental/18/daqmx-for-desktop-linux-tools.html
  3. Windows vs Desktop Linux DAQmx Experience Differences: https://www.ni.com/en/support/documentation/supplemental/18/windows-vs-desktop-linux-daqmx-experienc...
Please note that the installation repo is hosted online and the desktop Linux would need internet access to install the repo.
At the same time, RHEL user would need subscription to install the required dependencies.
Senior Technical Support Engineer | CLD CTA | NI
DISCLAIMER: The attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments. You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at: http://ni.com/samplecodelicense
(3,036 Views)
Hi ZY_Ong,
Thank you. That't the things that I am currently working at with our IT Team now  - to allow an Internet connection with my machine. I will let you know the results once I got net connection working.
(3,024 Views)
