Linux Users
Labview friendly linux distro
www.scientificlinux.org
Labview 2009 and hw drivers install flowlessly
(4,565 Views)
HI Giordy
Could you please explicit the meaning of your message?
The message which I received just says "www.scientificlinux.org; Labview 2009 and hw drivers install flowlessly"
Indeed late in Jan 2010 I easily installed Labview 2009 under Linux SLC4 but swiftly removed it because the package does not include the DAQ wizard, which under the other OS would have simply and effciently solved my problem and saved days of work to do the same using the C interface and GTK.
I did report that in message http://decibel.ni.com/content/message/12899#12899
Thus I would like to know if your message implies the availability of something new with respect with the Labview and drivers which were available 10 months ago..
Yanqele
(3,620 Views)
Hello
Could you release your code ? I think it could be useful as a starting point for several people using NI-DAQ under linux
It's just a proposition
Regards
(3,620 Views)
