Linux Users
Linux labview 10.0 reports: task niDriverThread:7696 blocked for more than 120 seconds
I just received and installed Linux labview 10.0.0 on openSuse 11.2 i586.  I have a question:
When I tried to instal NI-488 (2.5.1), it complained that it can't handle a kernel configured for greater than 4GB of memory.
I'm willing to accept that limitation, so I modified the stock opensuse 11.2 kernel .config (2.6.31.14-0.4-desktop as in the latest patches) to use the 4GB memory model.  I rebuilt the kernel and modules and rebooted.
At that stage, I was able to build and load the ni modules and communicate with my NI-PCIe 488 board.
lsmod shows:
Module                  Size  Used by
NiViPciK               81984  0
nipxirmk              119304  1
nidimk                337696  2 nipxirmk
niorbk                108788  2 nipxirmk,nidimk
gpibprtk              252820  0
nipalk               1295316  8 NiViPciK,nipxirmk,nidimk,niorbk,gpibprtk
nikal                  78168  1 nipalk
The problem is that I am getting INFO messages upon module loading.  These INFO messages repeat every 120 seconds for five iterations and then I believe it stops.  Is this a problem?  The communication with the NI-PCIe 488 board is working.  Thanks for any help on this matter.
Here is the dmesg output:
[  160.828193] nikal: module license 'Copyright (c) 2002-2010 National Instruments Corporation.  All Rights Reserved.  Any and all use of the copyrighted materials is subject to the then current terms and conditions of the applicable license agreement, which can be found at <http://www.ni.com/linux/>.' taints kernel.
[  160.828217] Disabling lock debugging due to kernel taint
[  160.977017] ni488 0000:04:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[  161.020363] IRQ 16/nipalk: IRQF_DISABLED is not guaranteed on shared IRQs
[  360.806935] INFO: task niDriverThread:7696 blocked for more than 120 seconds.
[  360.806944] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[  360.806952] niDriverThrea D f420dde4     0  7696      2 0x00000000
[  360.806961]  f420ddfc 00000046 00000002 f420dde4 c2b94850 00000000 017d7840 0000ad5d
[  360.806974]  00000000 fffde1a5 02faf080 c09a8850 c09ace40 f572a83c 7d8f322c 00000025
[  360.806987]  f572a83c 7d8f2874 00000025 f64df580 f572a5b0 f420ddec 00000000 00000000
[  360.806999] Call Trace:
[  360.807015]  [<c066ed15>] schedule_timeout+0x185/0x200
[  360.807024]  [<c066dba3>] wait_for_common+0x93/0x140
[  360.807033]  [<c066dd91>] wait_for_completion+0x21/0x40
[  360.807052]  [<f7ca0879>] nNIKAL100_waitForSingleUseEvent+0x19/0x40 [nikal]
[  360.807172]  [<f85b8524>] nipalk-unversioned0002660+0x2b8/0x2f4 [nipalk]
[  360.807277]  [<f85b8267>] nipalk-unversioned0002644+0x13/0x18 [nipalk]
[  360.807296]  [<f7d932ee>] gpibprtk-unversioned0000705+0x22/0x68 [gpibprtk]
[  360.807312] DWARF2 unwinder stuck at gpibprtk-unversioned0000705+0x22/0x68 [gpibprtk]
[  360.807318]
[  360.807321] Leftover inexact backtrace:
[  360.807322]
[  360.807427]  [<f85b47ed>] ? _Z16threadMainLinuxKPv+0x59/0x7c [nipalk]
[  360.807546]  [<f85b4794>] ? _Z16threadMainLinuxKPv+0x0/0x7c [nipalk]
[  360.807567]  [<f7ca0960>] ? nNIKAL100_threadMain+0x0/0x60 [nikal]
[  360.807586]  [<f7ca0999>] ? nNIKAL100_threadMain+0x39/0x60 [nikal]
[  360.807599]  [<c0267eb4>] ? kthread+0x84/0x90
[  360.807608]  [<c0267e30>] ? kthread+0x0/0x90
[  360.807623]  [<c0204c2b>] ? kernel_thread_helper+0x7/0x1c
[  360.807635] INFO: task niDriverThread:7697 blocked for more than 120 seconds.
[  360.807647] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[  360.807660] niDriverThrea D f5461de4     0  7697      2 0x00000000
[  360.807675]  f5461dfc 00000046 00000002 f5461de4 c2b94850 00000000 0000b964 daecfb04
[  360.807699]  f5461e10 fffde1a5 0000000a c09a8850 c09ace40 f429b5bc 7d8f8f61 00000025
[  360.807722]  f429b5bc 7d8f884d 00000025 f64df580 f429b330 f5461dec 00000000 00000000
[  360.807746] Call Trace:
[  360.807759]  [<c066ed15>] schedule_timeout+0x185/0x200
[  360.807774]  [<c066dba3>] wait_for_common+0x93/0x140
[  360.807788]  [<c066dd91>] wait_for_completion+0x21/0x40
[  360.807809]  [<f7ca0879>] nNIKAL100_waitForSingleUseEvent+0x19/0x40 [nikal]
[  360.807926]  [<f85b8524>] nipalk-unversioned0002660+0x2b8/0x2f4 [nipalk]
[  360.808037]  [<f85b8267>] nipalk-unversioned0002644+0x13/0x18 [nipalk]
[  360.808061]  [<f7d932ee>] gpibprtk-unversioned0000705+0x22/0x68 [gpibprtk]
[  360.808084] DWARF2 unwinder stuck at gpibprtk-unversioned0000705+0x22/0x68 [gpibprtk]
[  360.808093]
[  360.808097] Leftover inexact backtrace:
[  360.808098]
[  360.808209]  [<f85b47ed>] ? _Z16threadMainLinuxKPv+0x59/0x7c [nipalk]
[  360.808318]  [<f85b4794>] ? _Z16threadMainLinuxKPv+0x0/0x7c [nipalk]
[  360.808333]  [<f7ca0960>] ? nNIKAL100_threadMain+0x0/0x60 [nikal]
[  360.808347]  [<f7ca0999>] ? nNIKAL100_threadMain+0x39/0x60 [nikal]
[  360.808353]  [<c0267eb4>] ? kthread+0x84/0x90
[  360.808356]  [<c0267e30>] ? kthread+0x0/0x90
[  360.808362]  [<c0204c2b>] ? kernel_thread_helper+0x7/0x1c
Message 1 of 1
(3,367 Views)
