Linux Users
NI-KAL 1.9 on Fedora 10
Does NI-KAL 1.9 work on Fedora 10?
(6,044 Views)
I personally have not tried, but I see no reason why it wouldn't.  Give it a try and post your results.  You can even create a tutorial if you want like "How to install NI-488.2 on Fedora 10" (or whatever NI driver you want to install).  I suspect on Fedora 10 your tutorial would be something simple like "install NI-KAL 1.9 then install NI-488.2 2.5.1b1", but I'm sure it would help other users who are not using officially supported distributions.
Use NI products on Linux? Come join the NI Linux Users Community
(3,867 Views)
Shawn,
Thanks, but after some browsing, I have found the answer under "64 bit":
which is:
"OK, I have the latest ni-488.2 / nikal working fine on Fedora 10 x86_64, so I can use the interactive control to send commands to gpib equipment."
Ali
(3,867 Views)
