Linux Users
selinux problem?
I have ni4882-2.5.4b1-release.tar.gz and the new NIKAL 1.9 running on Fedora 10 x86_64.
There seem to be some issues until you disable selinux:
[root@xena ~]# /usr/local/natinst/ni4882/bin/gpibexplorer
Can't load LabVIEW runtime library /usr/local/lib/liblvrt.so.8.2
/usr/local/lib/LabVIEW-8.2/linux/libOSMesa.so.4: cannot restore segment prot after reloc: Permission denied
[root@xena ~]# setenforce 0
[root@xena ~]#
The above shows an error running gpibexplorer until "setenforce 0" is called to disable selinux.
Is this a known issue?
- Mike
(6,489 Views)
I am not an selinux user, but I get the feeling that you probably need to try something like is suggested here:
http://forums.ni.com/ni/board/message?board.id=170&message.id=369135
Run "/usr/bin/chcon -f -t textrel_shlib_t /usr/local/lib/linux/libOSMesa.so.4"
Cheers!
(3,860 Views)
