Linux Users
NI PXIe-6361 Linux driver
I am facing the following problem: I have a NI rack with a PXIe-6361 card connected to my PC, which is running ScientificLinux 7. Furthermore I am using a BNC 2090 Rack mount.
Although I installed the NI_DAQmx Base 15.0 drivers, the official NI documentation tells me that my card is not officially supported by this driver base. Therefore it's not suprising that I can't find any daq devices with my computer.
So my question here would then be, is there any way to make this card working with Linux, maybe some third party drivers? Or maybe someone knows a workaround of some sort? I really would hate to install Windows just because of that .
Cheers
(7,102 Views)
<snip>
Is there any way to make this card working with Linux, maybe some third party drivers?
PCIe X Series support on Linux is available through the Driver Development Kit (DDK).
FAQ
http://digital.ni.com/public.nsf/allkb/2D93070A3DDEFD7186256C59007289E6
The DDK is not a driver and an API, but a set of C/C++ source files that demonstrates the hardware's different features. Still, you should be able to reuse or remix the examples to suit your requirements.
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(6,768 Views)
OK thanks, I will try that!
Cheers
(6,768 Views)
directly passing through everything to userland ? running everything as root ? seriously ?!
*facepalm*
Linux Embedded / Kernel Hacker / BSP / Driver development / Systems engineering
(6,334 Views)
