Linux Users
NI-VISA Ubuntu 22.04 kernel 6.8 nikal.c error MAX_ORDER not defined
Hi!
I'm running into issues building the NI-VISA drivers on Ubuntu 22.04 with kernel 6.8 after system update. The error occurs when building nikal packages and propagates to all packages that depend on it.
I am posting the make.log from dkms below:
Making nikal.ko
warning: the compiler differs from the one used to build the kernel
The kernel was built by: x86_64-linux-gnu-gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0
You are using: gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0
CC [M] /var/lib/dkms/nikal/24.0.0f140/build/nikal.o
/var/lib/dkms/nikal/24.0.0f140/build/nikal.c:98:2: error: #error ("MAX_ORDER not defined, but is required.");
98 | #error ("MAX_ORDER not defined, but is required.");
/var/lib/dkms/nikal/24.0.0f140/build/nikal.c: In function ‘nNIKAL100_malloc’:
/var/lib/dkms/nikal/24.0.0f140/build/nikal.c:3219:26: error: ‘nNIKAL1400_kMaxOrder’ undeclared (first use in this function)
3219 | if (get_order(size) < nNIKAL1400_kMaxOrder )
/var/lib/dkms/nikal/24.0.0f140/build/nikal.c:3219:26: note: each undeclared identifier is reported only once for each function it appears in
/var/lib/dkms/nikal/24.0.0f140/build/nikal.c: In function ‘nNIKAL100_mallocContiguous’:
/var/lib/dkms/nikal/24.0.0f140/build/nikal.c:3242:20: error: ‘nNIKAL1400_kMaxOrder’ undeclared (first use in this function)
3242 | if (pageOrder < nNIKAL1400_kMaxOrder )
make[2]: *** [scripts/Makefile.build:243: /var/lib/dkms/nikal/24.0.0f140/build/nikal.o] Błąd 1
make[1]: *** [Makefile:1926: /var/lib/dkms/nikal/24.0.0f140/build] Błąd 2
make: *** [Makefile:92: nikal.ko] Błąd 2
Could I ask you for help in solving this problem?
In the case of the nikal package, I have often faced various types of problems while building it. The most common one was related to the stdbool.h source file.
(1,080 Views)
Accepted by StareLacze
(1,072 Views)
In my case it worked. The perfect solution. I had to update LabVIEW and NI-VISA drivers to version Q3. After restarting the computer, everything worked as it should.
Thank you very much for your help.
Could you merge this thread with another identical one? I posted the same post twice. This one has a more informative title.
Sorry about that.
(1,049 Views)
