Linux Users
NI-VISA does not work in wsl Ubuntu 24.04.1.
I have installed ni-software-2024-noble, ni-visa, ni-visa-devel.
~$ cat /etc/os-release
PRETTY_NAME="Ubuntu 24.04.1 LTS"
NAME="Ubuntu"
VERSION_ID="24.04"
VERSION="24.04.1 LTS (Noble Numbat)"
VERSION_CODENAME=noble
ID=ubuntu
ID_LIKE=debian
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
UBUNTU_CODENAME=noble
LOGO=ubuntu-logo
~$ uname -a
Linux DESKTOP-72NF22D 6.6.36.6-microsoft-standard-WSL2+ #1 SMP PREEMPT_DYNAMIC Sat Dec 21 14:22:40 CST 2024 x86_64 x86_64 x86_64 GNU/Linux
~$ sudo systemctl status nipal
× nipal.service - NI Core Driver Services
Loaded: loaded (/usr/lib/systemd/system/nipal.service; enabled; preset: enabled)
Active: failed (Result: exit-code) since Sat 2024-12-21 14:53:11 CST; 21min ago
Process: 6435 ExecStartPre=modprobe -q nipalk (code=exited, status=1/FAILURE)
Process: 6437 ExecStopPost=modprobe -r nipalk (code=exited, status=1/FAILURE)
Dec 21 14:53:11 DESKTOP-72NF22D systemd[1]: Starting nipal.service - NI Core Driver Services...
Dec 21 14:53:11 DESKTOP-72NF22D systemd[1]: nipal.service: Control process exited, code=exited, status=1/FA>
Dec 21 14:53:11 DESKTOP-72NF22D modprobe[6437]: modprobe: FATAL: Module nipalk not found.
Dec 21 14:53:11 DESKTOP-72NF22D systemd[1]: nipal.service: Failed with result 'exit-code'.
Dec 21 14:53:11 DESKTOP-72NF22D systemd[1]: Failed to start nipal.service - NI Core Driver Services.
~$ sudo dkms autoinstall
Error! Your kernel headers for kernel 6.6.36.6-microsoft-standard-WSL2+ cannot be found at /lib/modules/6.6.36.6-microsoft-standard-WSL2+/build or /lib/modules/6.6.36.6-microsoft-standard-WSL2+/source.
Please install the linux-headers-6.6.36.6-microsoft-standard-WSL2+ package or use the --kernelsourcedir option to tell DKMS where it's located.
dkms autoinstall on 6.6.36.6-microsoft-standard-WSL2+/x86_64 failed for nikal(1)
NiViPciK/24.8.0f135 autoinstall failed due to missing dependencies: nikal nipalk
ni1045tr/24.8.0f118 autoinstall failed due to missing dependencies: nikal
nicmmk/24.8.0f118 autoinstall failed due to missing dependencies: nikal
nicntdrk/24.8.0f121 autoinstall failed due to missing dependencies: nikal
nicpciek/24.8.0f117 autoinstall failed due to missing dependencies: nikal
nidimk/24.8.0f172 autoinstall failed due to missing dependencies: nikal niorbk nipalk
nimdbgk/24.8.0f145 autoinstall failed due to missing dependencies: nikal niorbk nipalk
nimru2k/24.8.0f172 autoinstall failed due to missing dependencies: nidimk nikal nimdbgk nimxdfk niorbk nipalk
nimxdfk/24.8.0f145 autoinstall failed due to missing dependencies: nikal nimdbgk niorbk nipalk
nimxik/24.8.0f119 autoinstall failed due to missing dependencies: nikal
niorbk/24.8.0f145 autoinstall failed due to missing dependencies: nikal nipalk
nipalk/24.8.0f145 autoinstall failed due to missing dependencies: nikal
nipxicidk/24.8.0f121 autoinstall failed due to missing dependencies: nikal
nipxiethernet/24.8.0f118 autoinstall failed due to missing dependencies: nikal
nipxifpk/24.8.0f123 autoinstall failed due to missing dependencies: nikal nimdbgk nimxdfk niorbk nipalk nipxirmk
nipxigpk/24.8.0f123 autoinstall failed due to missing dependencies: nikal nimdbgk nimxdfk niorbk nipalk nipxirmk
nipxim2/24.8.0f118 autoinstall failed due to missing dependencies: nikal
nipxirmk/24.8.0f123 autoinstall failed due to missing dependencies: nidimk nikal nimdbgk niorbk nipalk
nismbus/24.8.0f121 autoinstall failed due to missing dependencies: nikal
Error! One or more modules failed to install during autoinstall.
Refer to previous errors for more information.
The default installed wsl2 uses the 5.15 kernel. I think the driver and kernel version do not match, so I manually upgraded to the latest wsl kernel 6.6, but it still does not work.
Can anyone help me? Thanks!
(1,614 Views)
WSL does not support installing kernel modules.  At the very least, the NI-VISA PXI passport installs a kernel module.  If you don't need that passport, you could possibly install VISA without that passport to get it working.  That wouldn't be a configuration supported by NI, but it may allow you to get something working.
(1,576 Views)
Accepted by Summpot
The following worked for me on a WSL Ubuntu 24.04.1 install:
sudo apt-get install ni-visa ni-visa-devel ni-kal-
Since nearly all NI kernel modules require NI-KAL, preventing it from installing (with the - suffix) ensures that no NI kernel modules are installed.
(1,571 Views)
I'll try it next week, thanks for the help.
(1,563 Views)
