Linux Users
Ubuntu 12.04 (kernel 3.2) and niDAQmx: libnipalu.so issues. Can it be made to work?
I am trying to make niDAQmx work on a Ubuntu 12.04 32-bit machine, with kernel 3.2. I had some success before with ubuntu 10.10 (see https://decibel.ni.com/content/message/25254). Here I am using the exact same versions of NI software (ni-kal 2.1, DAQmx 8.02). I had to modify slightly nikal.c in the nikal module to get around the ioctl / compat_ioctl issue with recent kernels (see attached file nikal.c.patch). Once this is done, and with steps similar to the Ubuntu 10.10 setup, one has :
lsmod|grep ni
nissrk               2042495  0
nistcrk               189457  1 nissrk
nistc2k               227493  2 nissrk,nistcrk
nitiork              1002687  1 nissrk
nicdrk                372290  3 nissrk,nistcrk,nitiork
nimru2k               430085  3 nissrk,nistcrk,nitiork
nimxpk                 41736  5 nissrk,nistcrk,nistc2k,nitiork,nicdrk
nipxirmk              120058  0
nidimk                328631  3 nitiork,nimru2k,nipxirmk
nimsdrk               237610  3 nissrk,nistcrk,nitiork
nidmxfk               380304  5 nissrk,nistcrk,nitiork,nicdrk,nimsdrk
nimxdfk               482184  7 nissrk,nistcrk,nitiork,nicdrk,nimru2k,nimsdrk,nidmxfk
nimstsk                83261  6 nissrk,nistcrk,nitiork,nicdrk,nimsdrk,nidmxfk
nimdbgk               366412  10 nissrk,nistcrk,nistc2k,nitiork,nicdrk,nimru2k,nimsdrk,nidmxfk,nimxdfk,nimstsk
niorbk                101451  12 nissrk,nistcrk,nitiork,nicdrk,nimru2k,nipxirmk,nidimk,nimsdrk,nidmxfk,nimxdfk,nimstsk,nimdbgk
nipalk               1229948  16 nissrk,nistcrk,nistc2k,nitiork,nicdrk,nimru2k,nimxpk,nipxirmk,nidimk,nimsdrk,nidmxfk,nimxdfk,nimstsk,nimdbgk,niorbk
nikal                  61822  1 nipalk
The nipal service also starts properly and creates  /dev/nipalk as expected; other NI services do not complain. However, all NI utilities fail with the message
libnipalu.so failed to initialize
In syslog, more info is given, for instance when launching nilsdev :
nilsdev: [nipalu]  Warning: source/lib/linux/linLoadKern.cpp:97 - libKernelDriverInit: Failure loading kernel driver. status=-50202
nilsdev: [nipalu]  Warning: source/initcln/initcln.cpp:147 - Posix: Init kInitClnPackage: kernelDriver: failed! status=-50202
nilsdev: [nipalu]  Warning: source/package/posix/ulibEntry.cpp:179 - initialize: unable to load NI-PAL. status=-50202
It seems that libnipalu.so does not see that nikal / nipalk is already loaded.
Is there some way to overcome this ?
(9,657 Views)
My guess is that you're not patching NI-KAL correctly. If HAVE_COMPAT_IOCTL is defined, you're not defining ioctl in the driver structure.
Considering most of our software communicates to our driver using mostly ioctl, the error you're seeing is understandable if ioctl isn't done right.
I'm not sure how to patch the ioctl correctly. I haven't kept track of the kernel changes for a while.
Exactly what error did you encounter when you compile KAL against your kernel?
(4,408 Views)
with the original source, I get :
/usr/local/natinst/nikal/src/nikal/nikal.c:489:4: error: unknown field ‘ioctl’ specified in initializer
/usr/local/natinst/nikal/src/nikal/nikal.c:489:4: warning: initialization from incompatible pointer type [enabled by default]
/usr/local/natinst/nikal/src/nikal/nikal.c:489:4: warning: (near initialization for ‘nNIKAL100_fops.fsync’) [enabled by default]
make[2]: *** [/usr/local/natinst/nikal/src/nikal/nikal.o] Error 1
make[1]: *** [_module_/usr/local/natinst/nikal/src/nikal] Error 2
make: *** [all] Error 2
(4,408 Views)
See if there's a new NI-KAL that just works for that kernel.. looks like 2.3.1 is avail:
http://joule.ni.com/nidu/cds/view/p/id/3477/lang/en
I see that 2.3 has some changes to address the ioctl probs.
(4,408 Views)
Based on your previous comment this is what I did - using nikal 2.2-f0 from NI-VISA that does not need patching (only the compile scripts need to have their kernel version check disabled). nilsdev and DAQmxtestpanels works, thank you !
(4,408 Views)
