Linux Users
please help me..
i can configure samba on centos 5 and can access  with other centos,. but i can't  connect with  windos mechine please help.
(4,586 Views)
This is a discussion group for the use of NI products in combination with Linux, not a generic Linux support forum. You would be better of to try to find user discussion forums for the specific software system you are using. In this case that would be Samba. Please make an attempt to find the actual user discussion list and don't try to bother the development lists with such question though. Most professional open source development teams don't respond well to user questions in their development discussion list.
Rolf Kalbermatter  My Blog
(3,944 Views)
Thanks rolfk!
mohithpm: you might want to participate in this mailing list: https://lists.samba.org/mailman/listinfo/samba
"This list is for all discussion between people using Samba and looking for help understanding it or installing it."
(3,944 Views)
Samba can be tricky to setup.   I've had varying degrees of luck with different distributions.
Have a look through this document.  It should give some direction.   http://www.techotopia.com/index.php/Sharing_Files_between_CentOS_6_and_Windows_Systems_with_Samba
Patrick Allen: FunctionalityUnlimited.ca
(3,944 Views)
