Lookout
ABS function bug in Lookout 6.6
I ran across this issue when recompiling one of my process files that uses the absolute value function. Some time after creating an expression using the absolute value function, if I go back to that expression, "abs" will be replaced with "must range between -1 and 1. The result is output in radians and ranges from 0 to PI" (see attachments). The absolute value will still be calculated, but if you recompile your process file you will get syntax errors.
I do not know if any other functions are affected in this way.
Jason Phillips
Message 1 of 13
(8,784 Views)
It's a bug
Ryan Shi
Message 2 of 13
(8,758 Views)
Is there a fix for the ABS function bug in Lookout 6.6?
Message 3 of 13
(8,671 Views)
Hi Ryan
I have now the same problem with the ABS function in Lookout 6.6
Is there a fix available?
Best regards
Dennis
Message 4 of 13
(8,559 Views)
I recall back in 5.1 there was a bug that would cause Symbolic Links to be replaced with "INVALID SIGNAL", causing the L4P and LKS to be corrupted.
Mike
Forshock - Consult.Develop.Solve.
Message 5 of 13
(8,545 Views)
Ryan, I am having this problem, what is the fix or work around?
Message 6 of 13
(7,771 Views)
What's your lookout version?
I don't remember there is a workaround. If it's not old version, I can build a fix for you.
Ryan Shi
Message 7 of 13
(7,736 Views)
Lookout 6.6 (build 49152)
Message 8 of 13
(7,734 Views)
Sent you a message. I'll build a fix and send to you.
Ryan Shi
Message 9 of 13
(7,713 Views)
Why not actually release it as a patch, you know how NI used to do things before every bug fix/introduction is a new "version".
Message 10 of 13
(7,692 Views)
