Lookout
SQLEXeC
Dear Expert,
I am using SQlEXEC in order to iunsert some data to an SQL data base, but unfortunetly this error accured.
[Not Buffered] 28000/18456: [Microsoft][ODBC SQL Server Driver][SQL Server]Login failed for user ''..
P.S: i can use same OBDC DSN with othe applicatiopn.
Danesh
(5,215 Views)
It sounds like a problem about your ODBC SQL Server access permission. Could you check that first?
(5,149 Views)
I agree. but how can I check permission, I can access ODBC via MS excel but not working with lookout.
regards
Danesh
(5,129 Views)
I suggest that you should send your code to lookout.support@ni.com, and the expert there could help to solve your problem.
(5,099 Views)
