Lookout
After I create a Timer (elapsed time meter) linked by an expression object, the parameter which was supposed to be the time it have counted, is harshed like 0.000012 or stuff like that. Whats the problem?
The reason you are seeing a "harshed" number like 0.000012 is because you have your ElapsedTime object set up in a general numeric format. If you right click on the object and go to display properties, you will have the option to change the numeric format to something more applicable. For example, by selecting HH:MM:SS, you will display the elapsed time that your expression is true in hours, minutes, and seconds.
(3,035 Views)
