Lookout
Upgrading from 4.01-b51 to 4.5-b9
There appears to be a problem when migrating a Lookout installation from
V4.01-b51 to V4.5-b9 when the same directory is re-used, i.e.
"C:\Lookout4".
The file "colorbar.dll" is not overwritten by the new install routine
and so you end up with the "colour selector" from V4.01. Then if you try
to modify the background colour of a "panel" they all become black and
cannot be modified.
(3,166 Views)
Been there, done that..........
You have to uninstall 4.01 first and then install 4.5. Move your .LKS files and any other custom graphics, etc to a "safe" place before uninstalling 4.01.
The new install will go well and give you the new color pallet. Recompile your processes and you're back in buisness.
PS. Go right to 4.5 build 13 and be current.
Good luck, Mark
(3,166 Views)
