Lookout
Can I link up Lookout to AS400?
(2,903 Views)
I am not aware of any direct interfaces to an IBM AS/400. However, Lookout can communicate under a number of protocols that you could use to communicate. For example, if you have an rs-232 connection on the AS/400, then you could communicate using the ASCII object over the serial port.
Greg
(2,903 Views)
