Lookout
Logging Alarms to CSV file Automatically
Does anyone know of a way to get Lookout 4.5 to "print" the alarm log
(preferably with filters) to a csv file automatically? In the PRINT option
under the alarm panel you can create a nice JOURNAL or SNAPSHOT manually. I
would like to have a timer or button from Lookout create the csv file
similar to the SPREADSHEET object.
I think it can be done with the SQL command to the Citadel database, but
that seems cumbersome.
Any ideas?
(3,121 Views)
why not just use a spreadsheet object that logs every time $alarm.update goes high or when $alarm.ack goes high. You shuld be able to use text blocks to create filters.
(3,121 Views)
