Lookout
Can I use Advantech´s PCL-718 with Lookout 3.6?
I like to know if it`s possible to use Advantech`s PCL-718 because Lookout only has driver for Advantech`s PCL-711B
(2,947 Views)
Usually, if the PLC type that you want to use is not listed on the driver's description or the driver's drop down menu, it is not supported. But, if the PLCs are very similar (same communication protocol, same addressing, etc), it might work...but the only way to know is by testing it.
(2,947 Views)
