Lookout
Can I use the Advantech´s PCL-718 with Lookout 3.6 ?
I need to know if Lookout has a driver for Advantech´s PCL-718 because only I found driver for Advantech`s PCL-711B
(3,107 Views)
If this PLC is not listed on the drop-down menu of the driver, it is not officially supported, but if the PLCs are very similar, it might work. Once again, the only way to know is by testing it. If it does not work, there is not a driver for it.
(3,107 Views)
