Lookout
XP Embedded Component
We are migrating our Lookout from Windows 2000 Professional to Windows XP Embedded to minimize the footprint.
Do you have an SLD file containing all the files/reg entries to incorporate into our runtime image so lookout does not have to be manually installed - we plan to use it as our windows Shell.
Altenatively do you any documentation that indicates what files, reg entries, etc. are initiated during install?
I look forward to your prompt reply.
Joshua Smith
IT Administrator
Flightship
www.flightship.net
(3,483 Views)
Joshua,
We do not have an SLD file for embedded OS's. Neither do we publish a list of all files, registry entries and dll's that are installed when Lookout is installed.
You can try to do a custom install to eliminate any "extra" files. However, we do not officially support Lookout on embedded OS's.
Again, you may just have to perform a custom install and try Lookout on the OS.
(3,483 Views)
Joshua-
You can use two freebee utilities to track registry entries-
InCntl5 monitors additions, changes, and deletions to registry entries and files when you install the SW on your development system, and you can use the output listing in conjunction with the "import registry branch" and "Files in Folder" tools in the Component Designer.
Depends monitors file usage while your application is running, so you know to add specific windows components in your base configuration in Target Designer, such as certain DLLs that Labview calls that wouldn't be included in a stripped version of eXP without adding additional bulky windows XP components.
If you have any questions, you can email me- I'd be glad to help
grekATneoceraDOTcomNOSPAM
(3,483 Views)
