Lookout
Can't recompile Lookout 6.7.1 file
I'm trying to convert a Lookout 6.1 file to 6.7.1 but keep getting recompile errors.  I've opened the source file and tried to fix the errors in notepad, but some of the syntax errors are not there and it doesn't make sense.  I've also fixed some of the errors only to have new errors appear when i recompile.  I'm hoping an administrator will take a look at my file to see if they can do the conversion.
(3,628 Views)
Here is the 6.1 file in question...
(3,580 Views)
I tried to open your source file in Lookout 6.1, however it failed, a warning window pop up, saying Backup Files: Could not load class.
Maybe you have used some backup files which are not included in Lookout.
(3,541 Views)
